My Internet is dead. Possible bad home run to the hub. Someone else is going to have to lead the raid and do the window. I may be fucked till Saturday...
Help me Obi Wan Kenobi
Started by
ExuuN
, Nov 14 2013 01:02 AM
20 replies to this topic
#1
Posted 14 November 2013 - 01:02 AM
Live by the sword, Die by the sword.
#2
Posted 14 November 2013 - 02:37 AM
#3
Posted 16 November 2013 - 07:20 AM
Did you get comcasted?
#4
Posted 16 November 2013 - 05:09 PM
#5
Posted 16 November 2013 - 05:18 PM
#6
Posted 16 November 2013 - 06:36 PM
#7
Posted 26 November 2013 - 02:18 AM
Just installed and updated a radeon 7970 from a gtx 580. Now Conan is displaying an error message:
Failed to initialize GUI. Help me Geeky Wan. You're my only hope... Or google, but I've turned up nil with the latter, so yeah... >.>
#8
Posted 26 November 2013 - 04:42 AM
Have you tried going office space upon that motherfucker?
If AOC client is giving you the error msg, have you gone through conanpatcher rebuild database yet?
Have you rebooted in safemode to remove all nvidia drivers yet? (nasty file remover).
#9
Posted 26 November 2013 - 11:57 AM
Yeah, I did the safe mode file removal. It won't even let me start the patcher
You know, the demon on my shoulder did whisper to rip that bitch out and throw it out the window, but I was like naaaaaaah. Maybe if I would have installed the card with "it feels good to be a gangsta" playing, I may not have had an issue.... Hmmmm...
#10
Posted 26 November 2013 - 12:28 PM
#11
Posted 26 November 2013 - 01:01 PM
You should channel the inner Asian in you and the problem will be fixed in no time. If you can't then you should really think about converting.
Ha.
Well anyways, I don't know where you are in your troubleshoot, ie, have you figured out if it's a video card/drivers problem or is it an aoc install/client problem?
I recently had to wipe c drive and reinstall windows. Aoc was on a diff drive and had to be "reinstalled" b/c the game wouldn't work. What I did was used the web download exe, installed the client in a different drive, allowed it to update a few times to get the conanpather up to date. I would then force quit the client, copypasted the original aoc folder into the new one but leaving some of the "key" files (like localconfig), and asked the game client to reverify the game. The game would then start, while windows would prompt things about starting online clients for the first time. After the game start I then configured the resolution and sound preferences, and quit the client. Now I, skillfully, simultaneously installed both AOCQS while copypasted my old preference files to the new AppData/Local/Funcom folder under windows users. Yup, multitasking, so much skill. Only Asians can do it, and now the game was good to go.
So let us know what part you're on, what you've tried, hopefully you get lucky and get it working without having to go through everything.
#12
Posted 26 November 2013 - 02:21 PM
For some reason I think I got this error before... i cant remember for the life of me how i fixed it. But i am kinda thinking reinstall aoc. Like full reinstall...
Ive never been a huge fan of the whole directory copy thing - for many reasons. One of which being if you just copy / paste the directory without doing the initail install, registery changes to support the program arent being made. While it may work, I think it not installing properly will corrupt your Windows registery (and the game) over time. Also, if your copying and pasting, and you already have a problem in the game files, your just copying and pasting the problem to save a couple hours of download time.
I also think that the game installs different type of support based on what hardware you use. Specifically with video cards. So, you may need to reinstall it with the Radeon drivers present. Thats why im curious if other games work.
If you dont want to reinstall, the only other thing I would suggest is double checking the ui if you have a customized ui. I would try to update / reinstall it.
.... but I am not as knowledgable as some
gailfrey seems to know a lot - or some other folks like Tankzo, Sam and George may have better suggestions (i think they are all IT guys). I just tend to try a few things and then format when it does not work. :3
Posted 26 November 2013 - 03:12 PM
Yes! I must reach inward and focus my chi!
I found out before I went to bed when I ran dxdiag that direct draw and my 3d hardware acceleration was not enabled. I tried to look for an option to enable it, but it wasn't there. It just said not available.
I tried looking up my display options in the control panel, but didn't see an advanced tab.
I did install Catalyst for my Amd drivers and updated Dx11 ( it did that automatically with the install), but I got stuck because I couldn't, or didn't have the option to enable direct draw and my 3d acceleration. It's prolly something bonehead simple.
#14
Posted 26 November 2013 - 03:13 PM
I did try other games, and none worked. Likely because of DD and 3D Acc.
#15
Posted 26 November 2013 - 04:46 PM
This might help.
Also AMD released new beta drivers 4 days ago, maybe it'll help your case.
#16
Posted 26 November 2013 - 05:35 PM
How is your monitor connected? I mean like what type of connector? Arent some of those options enabled / disabled based on what type of monitor / how its connected too?
Posted 26 November 2013 - 06:03 PM
Thanks Gali and Georgie. Gonna try some of that out when I get home from work.
My monitors are connected as such: one through a dual link dvi-d to active mini display port (secondary monitor), the primary is simply connected via dvi cable directly to the dvi-d port.
#18
Posted 26 November 2013 - 08:42 PM
DADV?
http://www.youtube.com/watch?v=BVfPV8jfh-4
#19
Posted 26 November 2013 - 10:49 PM
#20
Posted 27 November 2013 - 01:00 AM
I don't wanna sound like a queer or nothing, but have you fixed your shit yet?
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
Sign In
Create Account
Back to top
