You should hit them up about that. Maybe get a credit for something. Doing a pre-order then receiving it 6 days after the release is bullshit.
Addition of a BF BC2 Server?
Started by
Hemi
, Mar 05 2010 12:48 AM
38 replies to this topic
#21
Posted 07 March 2010 - 03:27 AM
#22
Posted 07 March 2010 - 04:26 AM
I wish I could play on our server. Never the fuck again will i preorder a game from BestBuy. Fuck them!
You earned yourself a new rank, soldier. I'm not even going to start playing until tomorrow night, so I'll be in the same boat. Also, we start out with no ammo packs, no meds, no paddles, no wrench, etc.
#23
Posted 07 March 2010 - 08:23 PM
#24
Posted 07 March 2010 - 09:58 PM
Beta worked great for me.
We carve the marks in your flesh to attest to the fact that we can't forgive and we won't forget.
#25
Posted 08 March 2010 - 12:09 AM
#26
Posted 09 March 2010 - 03:14 PM
#27
Posted 13 March 2010 - 05:38 PM
#28
Posted 14 March 2010 - 12:18 AM
#29
Posted 14 March 2010 - 01:21 AM
Buy it.Is it worth buying? $59 i think
Yes. $49 US.
#30
Posted 14 March 2010 - 01:35 AM
i"ll send you my key, my card is toast, I am done for awhile....
I am gonna try to bake again tomorrow..
#31
Posted 14 March 2010 - 02:09 AM
If you did, I might just have to send you a picture of my rubber ducky.
All 3 Eb-games stores are sold out here.
#32
Posted 14 March 2010 - 02:30 AM
#33
Posted 14 March 2010 - 06:46 AM
http://www.direct2dr... ... camp=fplni
Buy it. Download it. Play it.
if the bake does not work, I'll send ya my key
If you get it working again, download RivaTuner, set your fan speed to 100%, and load on startup. Nvidia's drivers have our cards running way too hot over the past 18 mos. or so.
#34
Posted 14 March 2010 - 04:10 PM
Ok, the card works again, cleaned fan and fins, fan is running at 100%, but I am not convinced it it is moving enough air. When I place my hand behind the case where the video card is, there is not much air movement, right now it is luke warm air, but if I play it is pushing out hot air, so maybe I need to mod the card cover. Gona play with placing a pusher fan over the fan intake.
Any other ideas?
#35
Posted 14 March 2010 - 04:45 PM
Get GPU-Z and make sure your card's fan is running at 2900+ RPM, and that your idle temperature is around 60C. Under full load, these cards will run around 75-80 degrees. If it's nearing the mid to high 80s, then your case doesn't have sufficient airflow. Nvidia nTune is garbage, so don't use it for temps or fan control.; its numbers are typically inaccurate.
#36
Posted 14 March 2010 - 04:50 PM
When i had a 7900gtx, I had it volt modded too overclock higher. It ran way hotter than stock, so I took the plastic cover off and zap strapped a 120mm fan right to the heat sink, it worked great.
#37
Posted 14 March 2010 - 07:10 PM
#38
Posted 14 March 2010 - 10:16 PM
This is the idle snapshot. I'll add another after a few rounds of BFBC2
http://gpuz.techpowe...0/03/14/dyq.png
Your card runs at cooler temperatures than most everyone else'. You should be fine; I baked my shenanigans, and its performance has been amazing ever since.
#39
Posted 22 March 2010 - 06:27 AM
So EA has the server filters backward. If you check "Punkbuster" in the server browser, then your list will return servers with PB off. This is why most of our servers dwindle to empty; people check PB, and end up in PB-disabled servers. I'm guessing this is something they'll fix soon.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Sign In
Create Account
Back to top
