Bot - Need some SQL Assistance
#1
Posted 07 March 2015 - 08:20 PM
The bot runs on a series of SQL databases. I have MYSQL Workbench installed. Somehow in trying to export them, I fear I may have locked myself out of the system.
So basically, I have two problems:
1) I cant connect to the local instance of MySQL anymore. It keeps saying access denied
2) Once in MySQL (or I have a year old back up of the bot), I do not know how to export the quotes. The field type the actual quotes are stored in keeps showing up as "..." when I export them. I see them there, but I have to right click and choose "Edit field" to have the full text pop up. I suspect they are "Note" fields, which SQL is storing as some kind of blob.
Can someones halp.
(If the answer is not obvious to someone, but they know how to fix it, I can probably setup the remote assistance thing in Windows)
#2
Posted 08 March 2015 - 12:21 AM
I'm not sure how you could lock yourself out of MySQL after trying to export. I think I may be off Monday, so I'll try to get at it in the morning.
#3
Posted 08 March 2015 - 03:58 AM
Thanks man. Cata should be home Monday. Ill figure out how to setup the remote assistance
#4
Posted 11 March 2015 - 01:53 PM
So I'm trying to reinstall MySQL see if that will fix the password issue. I think that the password is set on the my SQL Server, not the database itself. if not I may need help getting the quotes out of the back up I have
#5
Posted 11 March 2015 - 02:24 PM
Yes; the db has nothing to do with a password. I run MySQL 5.1.73 and phpMyAdmin; are you using some Windows-ey admin?
#6
Posted 11 March 2015 - 04:28 PM
Thats a relief about the password. I was getting so angry at it last night. Lol
Is phpMyAdmin easy to use.... for me?
#7
Posted 11 March 2015 - 10:25 PM
Yeah. Maybe look up EasyPHP (it's an all-in-one suite), unless you get that one working. Probably better to run the bot from a decent PHP environment, anyway.
#8
Posted 12 March 2015 - 12:00 PM
I know i did it once when we moved servers for the login messages
#9
Posted 12 March 2015 - 03:15 PM
#10
Posted 12 March 2015 - 10:24 PM
I was trying to get it into Access because I know how to extract Note fields in Access. But for some reason, MySQL Workbench refuses to export the field into any format. I have to like open up the table record, double click on the field and only THEN will it show me its tasty goodness.
#11
Posted 13 March 2015 - 05:10 PM
#12
Posted 15 March 2015 - 12:50 PM
I think so, but all that did was create a bunch of sql files. I cant seem to get data out of these files
What directory does MySQL typically store its databases?
#13
Posted 15 March 2015 - 08:35 PM
#14
Posted 15 March 2015 - 09:54 PM
Yes, I think so. I have two options (I think):
- I have a relatively recent export of the bot databases to a SQL file. These are on my desktop
- I dont know where MySQL saves its data files, or in what format it saves them in. But I imagine if uninstalling MySQL does not remove these, they are still there (what format does it save them in? I can check)
#15
Posted 16 March 2015 - 12:07 AM
They'd be in a subdirectory of whatever MySQL program you're running. You wouldn't be able to go through them with a text editor, or anything. If you want, send me a complete SQL dump, and I'll see if I can do what you're trying to accomplish. I might build a little Linux box out of all this stuff I have laying around, so maybe I'll put up a bot for funsies with it.
I roam around and PvE out of boredom lately, anyway.
#16
Posted 16 March 2015 - 10:25 AM
Sure
I Can do that. Do you know what file extension they will be? For the MySQL files, that is. Not the sql export, those I know obviously lol
#17
Posted 16 March 2015 - 05:03 PM
Somewhere in "Program Files (x86)", you should have a "/mysql/data/[db name]/" directory, loaded with tables (.frm, MYD, MYI).
#18
Posted 18 March 2015 - 12:10 AM
Ok I cant find the actual database files. The only ones that are there are from when I tried to install EasyPHP. But, I have the export I did a little while ago on this PC. I also have a little bit of an older backup on dropbox if this does not work.
Theres two sets of backups on this PC. One is a full export from the Set(16) bot and the Tyranny (15) bot. The other one is just from Set, I think.
If these two dont have it, let me know and I can send you the backup from drop box. Its about a year old, so if were missing anything, its not a whole lot
Thank you so much again for doing this
I really dont want to lose these quotes
#19
Posted 18 March 2015 - 04:42 AM
#20
Posted 18 March 2015 - 10:06 PM
No worries
Like I said, worst case, I have about a year old back up on drop box.
I will make a copy of the files I posted here on my main PC (just in case) and work on re-installing windows on the bot.
Thanks again, bud
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
Sign In
Create Account
Back to top
